Wireframe Color
Wireframe Color
When I create parts, I set the wireframe color different than the shaded color. This allows me to look at a wireframe asembly and see functional parts instead of a mass of black lines.
Every assembly I have is not behaving properly. They display in wireframe as one color, sometimes black, sometimes the same color as the last part inserted. I haven't changed, updated, modified my system in about 6 weeks, so I am thinking that I must have accidently "flipped a switch" somewhere. Any suggestions?
SW05 SP4.0
SW05 SP4.0
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
RE: Wireframe Color
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe transcends reason.
RE: Wireframe Color
Anyway, in my assembly, with the option above selected, my wireframes for each part are the same color as the parts when shaded.
Jeff Mowry
RE: Wireframe Color
Also, I saw a commercial from LensCrafters, they will give you any color wireframe you want.
Chris
SolidWorks 06 5.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 10-27-06)
