Others Loads
Others Loads
Hi guys,
anybody can do advise us for this case..
We have project pressure vessels from PT Conocophilips Indonesia. Which one of client requirement from client spec. as below :
Extent of vessel loadings:
The actual thickness of pressure vessels and its associated parts shall be determined using the applicable worst combination of the following requiremnts (plus internal design/external design/hydrotest pressure), as minimum :
* Loads due to erection weight + wind loads,
* Loads due to empty weight + wind loads,
* Loads due to empty weight + wind loads + transportation loads,
* Loads due to operating weight + wind loads,
* Loads due to empty weight + wind loads + blast loads,
* Loads due to empty weight + 75% wind loads,
* Local stresses induced by the presure vessel support, or
* Local stresses induced by the nozzles localized load, using WRC 107 and 297.
We would like to know Compress handled this case, and if we get the loads from manual calculation, where we must input the data to codeware?
Yours trully
Adi Tjahjono S,
PT. MULTIFAB
MEDCO Building II, 3rd Floor
Jakarta 12560 - Indonesia
Yours trully
Adi Tjahjono S,
PT. MULTIFAB
