6kw CO2 laser cutting costs
Does anyone one have an opinion on whether or not cutting thick steel plate with a 6kw laser is cost effective?  Lets say vs. a plamsa or oxyfuel cutter.  The thickness is in the range of 25-35mm .
RE: 6kw CO2 laser cutting costs
I have been looking at several machines lately.  One of the companies has an editorial that may be of inrterest to you.I hope its ok to post a link because here it is http://www.plasma-cutter.com/ the company is torchmate.
Hope this helps.
Rollernose
It is very cost effective to use lasers. Especially if you want high cut precision and edge quality
