Printing Longer than A1
We have a HP Designjet plotter (uses a roll feed) and the largest drawing frame that we usually print (using AutoCAD 2005) is A1.
I need to print a template of an object that measures approx 14" x 54".  I tried a while back to print but with little success.  Does anyone know how to do it so that it would print out in one long sheet
Thanks in advance
RE: Printing Longer than A1
Go into the plotter config and set up a new size, paper width A1/A0 by whatever length you require and that should do the trick.
