6kw CO2 laser cutting
Does anyone one have an opinion on whether or not cutting thick steel plate with a 6kw laser is cost effective?  Lets say vs. a plamsa or oxyfuel cutter.  The thickness is in the range of 25-35mm .
RE: 6kw CO2 laser cutting
depends a lot on what you need, what the 6kW can offer, what it costs.
Do you need more precision or finer detail than the Oxyfuel or plasma can give you? Do you need the reduced HAZ depth that laser <should> give you?
Does the laser you have access to cut well? is the motion system smooth and accurate enough to give you the edge quality that you need?
start with the laser mfg's propaganda/specs
go from there...
let us know!
Jay
