Can one assign BCs on mesh nodes? if yes. How ?
Some BCSs like hydrostatic pore pressure must be assigned on mesh nodes  How can I prescribe BCs on mesh nodes . Do I have to make it orphan mesh in order to do so
RE: Can one assign BCs on mesh nodes? if yes. How ?
Pressures and so on are prescribed to surfaces and hence to element faces on the mesh when the input file is created.
corus
Hello corus
Pore Pressure (P.P) BCs are different from normal pressure BCs,as applying P.P BC will imply not only pressure force but also seepage (flow)iduction within the system
I did not find any indication in the Documentation showing that ABAQUS can apply hydrostatic pore pressure on a surface or edge....
Please let me know if you did
