Sand monitoring during production
I wonder if anyone knows any device capable of measuring sand quantities in kg of sand per barrels of fluid in a process pipe ?
Most sand monitoring devices i've come across only give indication of sand production but don't measure quantity.
RE: Sand monitoring during production
Once I read a paper where a non contact measurement of conductivity was used for the same purpose.
In both cases you need a carefully performed calibration.
It would be good to know more about your liquid and about the sand.
m777182
The problem is that the process is very often not a stable flow thus errors can occur.
What is the route of the pipeline downstream is it into a vessel / separator? There are many devices that would be able to monitor sand / solid build up in a vessel for instance a phase profiler.
THey have success in underflow measurement, pipeline measurement and in classifiers.
JMW
www.ViscoAnalyser.com
