O-RINGS
O-RINGS
O-RINGS
DOES ANYONE KNOW WHERE I COULD GET SOME INFO (FREE) ON
RECOMMENDED HOLE SIZE & DEPTH'S FOR STANDARD O-RING SEALS?
RE: O-RINGS
Parker has an excellent and FREE O-Ring handbook.
RE: O-RINGS
I believe this manufacturer is called Parker-Nichols and is in MASS.
RE: O-RINGS
I also think Green tweed or Greentweed.com
RE: O-RINGS
Hi John,
at busak and shamban (www.busakshamban.com) you can also find some valuable information. somewhere I must have a spreadsheet flying around with which you can determin the correct pre-load etc. its quite extended and can be used for o-ring selection very well. if you are interested I can look around where I saved it and send it.
regards,
arnold
