Relative Path xref
Relative Path xref
Relative Path xref
Why do I sometimes get a message that I cannot attach a certain xref using retative path, thus forcing me to use full path, which doens't work for our customer?
Somebody told me there is a setting or path that needs to be changed in options and file paths - does this make sense?
Cheers. Sean.
RE: Relative Path xref
(command "-XREF" "PATH" XREFNAME NEWPATH)
"Everybody is ignorant, only on different subjects." — Will Rogers
I am not sure I follow - with newpath, where I dont actually have a fixed path. Do you know why I am being stopped when trying to use relative path?
Cheers. Sean.
