CHILLER CARRIER, BEFORE/WATER, AFTER/GLYCOL
I have a chiller Carrier 30GTN210. AT THE MOMENT WORK COOLING WATER. BUT I WANT to PASS IT so that  WORK COOLING GLYCOL FOR TERMOACUMULACION. I have READ IN THE MANUAL THAT I should BUY THE module EMM to PROGRAM THEIR CYCLES OF WORK. IT ALSO SAY THAT I should CHANGE THE HOLE OF THE ELECTRONIC EXPANSION VALVE.
IF I CHANGE THE HOLE HOW OBTAIN SEVERAL SETTINGS??
RE: CHILLER CARRIER, BEFORE/WATER, AFTER/GLYCOL
Easiest way out.  Talk to the local Carrier service guy.
HVAC68
