( ôInsert>Feature>Combineö )
Does anyone know why this menu option ( “Insert>Feature>Combine” ) is grey out and cannot be chosen?
I’m trying to combine and subtract two bodies and cannot do it.
RE: ( ôInsert>Feature>Combineö )
Do you have 2 solid bodies in your part?  That's the most obvious reason why the command would be greyed out.  The "Merge Results" option is on by default when you create a feature - double check that you do in fact have multiple bodies.
... and are the bodies touching/intersecting?
cheers
Where do I need multiple bodies on an asssembly or a part document?
You need multiple bodies in a part document.  Combine is not an assembly feature.
I got it working
Thanks!!!
Multi-body parts use the Combine function.
Parts in an assy use the Join function.
cheers
I got it working, by this I meant by drawing two shapes in a part document but.... what about if you have the solid bodies in two different documents, how do you merge them outside an assembly?
How can I get two parts into a single part document? Please help!!
Insert, Part....
You could put them both in an assembly, and then go to File > Save As and save as a part file (*.sldprt).
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all.  And awe trumps reason.
dgowans (Mechanical)
Theophilus (Mechanical)
I did it both ways and this time it really works
Thanks a lot!!!!
