Copy/Cut/Paste Drawing Items
Is there a way to Copy/Cut/Paste drawing items, and keep the same relative origin to drawing? Example: I'm coping drawing notes from a "C" size drawing to another "C" size drawing and want them to fall in exact place when copy and paste. I’m using the same drawing templates when doing this. Is there any setting I need to adjust in the “Options” area? It's aggravating because it pastes the notes any old place.
I briefly searched past threads and really didn’t see anything for this.
Macduff ![[spin] spin](https://www.tipmaster.com/images/spin.gif)
Colin Fitzpatrick
Mechanical Design Engineer
Solidworks 2006 SP 4.1
Dell 380 XP Pro SP 2
nVida Quadro FX 3450/4000
RE: Copy/Cut/Paste Drawing Items
You may be able to modify it to suit.
You can zoom in on the corner of the sheet and move the view around until the endpoint of the line is on the corner.
SW07 SP2.0
Flores
Eric
SW07 SP2.0
Flores
