Bolt material for high temperature and H2S
Refer to NACE MR0175, acceptable bolt material for H2S service is A193-B7M.
In case of high temperature, A193-B16 should be better for strength concern. However, A193-B16 is not indicated in NACE MR0175.
Which is suitable material for high temperature and H2S service? Please comment.
RE: Bolt material for high temperature and H2S
Steve Jones
http://www.pdo.co.om/pdo/
Can you consider a stainless system like A-193-B8M? My "charts" indicate them to be good in corrosive environments and up to 1500 deg F. MR-0175 para 3.5.1 accepts austenitic stainless steel to within 22 HRC maximum and these studs are austenitic.
Can anyone reinforce this??
Steve Jones
