dimensioned lumber as diaphragms
Can anyone supply me with good sound information on using dimensioned lumber as diaphragms. I had some information years back but I cannot seem to relocate it. I have many documents on plywood as diaphragms but I need to see the possibility of using dimensioned lumber.
I have been intrigued over the discussion on STAAD.]
I have it. I use it but I don't trust it and i adhor REI and their arrogance.
RE: dimensioned lumber as diaphragms
The UBC also allows dimensional lumber to be used as a diaphragm if "calculated by principles of mechanics" This leaves the door open for some engineering creativity.
Good Luck
The 1997 Uniform Building Code contains design capacities for diagonally sheathed lumber diaphragms in section 2315.3. Visit http://www.awc.org/Codes/bldgcode.html for links to ICBO.
The International Building Code contains design capacities for diagonally sheathed lumber diaphragms in section 2306.3 Wood Diaphragms. Visit http://www.awc.org/Codes/bldgcode.html for links to ICC.
"Analysis Methods for Horizontal Wood Diaphragms" by Jephcott and Dewdney from proceedings of a Workshop on Design of Horizontal Wood Diaphragms (ATC-7-1) conducted by Applied Technology Council on November 19-20, 1980 (25 pages). Visit their website at http://www.atcouncil.org/ to order.
HTH
Buddy Showalter, P.E.
AF&PA/AWC
Byron
