compare matrix elements
Hi all. I'm new in matlab and i want to do smth like that:
Having two matrixes(vectors is better), like
A=[1;2;6;3;5;8]
B=[4;6;9;7;4;5]
I want to compare all elements of A to B, and if an element of A is same with one of B (not in same position necessarilly) to be written in another vector. In this example, i want to create a vector like
C=[6;5]
I spent many hours reading help documentation on matrixes but to no avail. I found smth like 'any' but did not understand it's functionality, and especially if it feets my needs.
Is this ....SO difficult...? I do not suppose so, but is there anyone here available to show me how?
Thanx in advance.
RE: compare matrix elements
Hi, the first thing I think to is to use for loops to control all position in both matrices.
[ra ca]=size(A);
[rb cb]=size(B);
t=1;
for i=1:ra
  for j=1:ca
    for k=1:rb
      for l=1:cb
        if A(i,j)==B(k,l)
          C(t)=A(i,j);
          t=t+1;
        end;
      end;
    end;
  end;
end;
There is another way, using function 'find':
[ra ca]=size(A);
[rb cb]=size(B);
t=1;
for i=1:ra
  for j=1:ca
    if isempty(find(B==A(i,j)))==0
      C(t)=A(i,j);
      t=t+1;
    end;
  end;
end;
Function find returns every value and index sattisfies the condition between brackets. If condition is not satisfied returns empty value. 'isempty' returns 1 if inside its brackets there is empty value.
I don't know which one is faster, because I think that behind function find there are for loops (and mabye for loops will be more direct). Only in case you work with larger matrixs.
Good luck
Jeez, that has to be a record for the greatest number of redundant "for" loops!
What is wrong with this
A=[1;2;6;3;5;8]
B=[4;6;9;7;4;5]
C=intersect(A,B)
M
Dr Michael F Platten
Thank you both. I will check for "help intersect" on the command window first and try some of the "for" loops as well, just to get acquainted with them. Thank you both ppl.
If A and B are the same length (and not too long!), this obfuscated one-liner will also work.  I'm not suggesting it's a good solution, but one that'll teach you a thing or two about Matlab.
B(sum(perms(A)==B(:,ones(1,factorial(length(A))))')>0)
At this point, the only thing i understand in the line above, is 'sum' (lol). It seems that i have to do a lot of reading!
Oh, i can also understand 'length' :P
(grateful)
