CuNi flange Mfg
CuNi flange Mfg
I'm working on a lubrication system for a US military project and have had a little trouble sourcing 70/30 CuNi flanges, fittings etc. through a mfg that has experience with military projects. Can anyone point me in the right direction? Thanks.
Brian
Brian
RE: CuNi flange Mfg
www.leebrass.com
www.alaskancopper.com
www.premiercopper.com
You could get forged or cast material depending on how you either spec it or who supplies it. If the material is to be a cast flange, make certain to ask for a weldability test per ASTM B369.
RE: CuNi flange Mfg
RE: CuNi flange Mfg
RE: CuNi flange Mfg
RE: CuNi flange Mfg
I've seen allowances for the use of slip-on flanges made from plate cu-ni but the use of those flanges is limited.
