How to select a right chain?
Hi All;
Can any expert out there tell me how to select a right chain? do i need a chain graph?
RE: How to select a right chain?
Assuming you are trying to spec heavy duty chain then this answer may not help you, but:-
Here in the UK there is a company called HPC Gears, they supply a booklet of there chain and gear sizes. in this booklet it gives you design parameters to allow you to choose the correct chain for any general application. It does make the distinction of having shock loading, etc and so is factored into the calculation process. i know this may not help you out if you live outside the UK, or are needing a quick answer.
Cheers
AndyR
If it's a transmission roller chain these are usually selected from the manufacturers selection charts.
http://
Russell Giuliano
Cheers,
CanuckMiner
The sprocket and gearbox information are as stated below:
Gearbox
Ratio: 31.39
Output torque: 1570 Nm
Service factor: 1.7
Output speed: 46 rpm
Drive shaft Dia: 60mm, 64mm including key
Pinion sprocket attached to the gearbox
No teeth:20
Pitch diameter:159.72mm
Magnetic drum sprocket
No teeth:57
Pitch diameter:461.07mm
center distance between two sprockets:1000mm
Someone had changed the chain recently but when it running it keeps loosing and tensioning until it rip the gear box into half. Can someone please explain to me why it had done that? the chain information is as stated below;
Chain
Chain pitch:25mm
Total length:3000mm
(AndyR05) I am in Australia
Thank you (diskullman) that website does help me a bit to understand how to select a chain but i still need more information to solve my problem.
Russell Giuliano
http
But what you need is this :--
htt
http://www.dolphin-ds.com/chnpower.htm
Something went wrong on the previous post ????
