Breather for upper-bearing oil bath
We have 4000HP 1200RPM vertical motors with oil bath housing the thrust bearing and upper radial bearing (segmented pad). The oil bath is cooled by cooling coils supplied by plant cooling water system. Oil temperature is around 100F.d (slightly warm to touch on external surface).
There is a breather on top of the oil bath compartment whose apparent purpose is to prevent ingress of dirt. However, a film of oil appears to be coming from the breather and coating the top of the motor and flowing down the sides (sometimes getting into air intake). As a first attempt to solve the problem we put a pipe nipple between motor oil bath and breather which moved the breather up approx 1' above top of the motor (should prevent any oil splashing). This was unsuccessful.
I'm thinking maybe warm oil vapors enter the breather and then condense on the filter as they hit the cooler atmosphere. Does anyone have any thoughts on this? Any suggestions for type of breather that may eliminate the problem?
RE: Breather for upper-bearing oil bath
Suggestion:
1. Replace filter (maybe dirty or plug)
2. Verify oil level, It seems a little high to me.
If possible, remove top cap, oil bath at stand
still or rest should come to the center of the
bearing.
Also most site glass levels are at the center
level of the glass at stand still or rest.
Kind regards,
motorhead
But what is causing the seepage from the breather ? I have seen this as the result of the oil foaming up into the breather (and even over the standpipe then into the motor). The foaming being because of contaminates in the oil. Do you see any foam in the sight glass when the motor as been operating for a while? Is this a new occurrence?
