WF3 ps2pdf setup
WF3 ps2pdf setup
i've searched, but can't find specifically what i'm looking for. i don't see the pdf option in our wf3 save as menu, so was gonna write a mapkey using a pcf file to send the ps to convert in pdf995 (ps2pdf995.exe). what's the command line for input and output to the working directory? does %HOME work?
thanks all,
Ed Lee
Sr. Designer
H2Gen
Alexandria, VA
thanks all,
Ed Lee
Sr. Designer
H2Gen
Alexandria, VA
RE: WF3 ps2pdf setup
Type drop down PDF(*.pdf) is the seventh one down.
Note: Can only do it in drawing mode.
thanks d.
Ed Lee
Sr. Designer
H2Gen
Alexandria, VA
