Help with plastic selection
I apologize if this isnt the correct plastic forum, but it was the closet I could find...
I'm in need of a plastic recommendation for a design. For all intents and purposes it can be thought of as a wiper for a wire rope. I need:
-High wear/abrasion resistence
-Some degree of natural lubrication
-Good elasticity properities (flexible)
-Impervious to most factory environment chemicals
-Injection moldable
I have no plastics experience, but my initial thoughts were low density PE, TPRs, or polyurethane. Can anyone give me a better recommendation, something more specific or point me in the right direction? Any info is appreciated.
-Injection moldable
RE: Help with plastic selection
Nylon will be best if high speed or high pressure generates a lot of heat.
Polyethylene will be cheap and has a greasy surface, but has a very low softening temperature.
Polyurethane has good flexibility and abrasion resistance, but the temperature resistance is not as good as nylon and the lubricity is not as good as PE
There is not any memory with less satisfaction than the memory of some temptation we resisted.
- James Branch Cabell
Dan - Owner
http://www.Hi-TecDesigns.com
