Datum Targets
Datum Targets
Datum Targets
 We are using Solidworks 2005, SP2. I have an extrusion model that is 4" X 3" X 70" long. We require datum points on the casting for inspection purposes, then also require datum points on the machining for set up purposes. The problem is that we can not get the datum point annotations to attach to points on a broken view. Actually, we can't even get the points to appear in the broken view at all. When the view is not broken, the points appear and datum targets appear normally. When the view get broken, the points appear far away from the views (where they were on the sheet before breaking the view). It appears that SWx has problems with broken views and points. We used 2D and 3D sketches to place our points on the models surfaces. Any help would be appreciated. The work around we are using now is to add small holes (for datum points dimensions) and to use a split balloon (for the datum point call out).
Garth
RE: Datum Targets
Instead of using points or small holes, have you tried placing a sketch circle or a circular surface at the required positions on the model?
cheers
RE: Datum Targets
Any 2D sketch acts the same as the points when the view is changed to a broken view. I did not try to "wrap" or "split" a circle on the surface. Those should work as they become 3D features of the part.
