Choosing rotating shaft seal for submerged water application
I'm trying to specify seals for an application as follows:
- submerged, freshwater (river water; not many particulates; some chance of suspended sand)
- max pressure: 3 psi
- max vacuum: 8 psi
- shaft speed: 520 RPM, continuous, single-direction (non reversing)
- surface speed: 1.4 m/s (4.5 ft/s)
- shaft hardness: 25-27 Rc
- desired life: at least 2 years continuous operation
I'm having trouble figuring out what seal to choose; it seems a mechanical seal is overkill given the low pressure and speed. Packing is leaky and maintenance-heavy. I've heard O-rings "are not good in dynamic situations". And lip seals damage the shaft and wear very quickly.
What is a good suggestion for the main shaft seal?
By the way, the shaft bearings (ball) are on the "dry" sides of the shaft (think of the application as a shaft going through a box filled with water under the above pressure). Should I specify both shaft seals at the "box walls" as well as bearing isolators?
Thanks for your help.
P.S. I posted this in the "Mechanical Seal Engineering" forum a few days ago, but haven't received any replies. Sorry if I offended anyone by re-posting in this forum.
- max vacuum: 8 psi
RE: Choosing rotating shaft seal for submerged water application
Don
Kansas City
Since you have bi-directional pressure, you may need 2 seals at each sealing point.
By far your best resource for information on this will be seal manufacturers such as Parker or Bal Seal.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
Never argue with an idiot. They'll bring you down to their level and beat you with experience every time.
