vessel thickness
vessel thickness
Hi
I will be pleased if you give me rule of thumb for
pressure vessel thickness calculation.
thanks for replyes
thanks for replyes
RE: vessel thickness
For relatively thin cylinders, approximately, t=PR/SE +CA, where P is internal pressure, R is radius, SE is allowable stress times joint efficiency, CA is corrosion allowance, with all units consistent. Typical values of SE might range from 12,000-20,000 PSI; CA perhaps 1/8". Thickness would normally be 1/4" or so minimum. These numbers could vary widely, though, depending on the application.
Why don't you just ask a structural engineer for a beam depth without any other information ?
Chem, before anymore time or keystrokes are wasted...are you an engineer and, if so, what country are you from ?
My opinion only
MJC
thanks for you input;
go ahead tell us about your dreams,
