Materials Data for ASME BPVC UG-101 Burst Test Calculation
I'm trying to determine the MAWP of a vessel based on burst testing using UG-101 P = B/4 X Smu X E /Smur. I have the burst test data, and I can find the minimum tensile strength of the vessel material, Smu(316L bar), but I do not have actual tensile data for the material that the burst test specimens were fabricated from. UG-101 allows an alternate calculation that uses Smur, the "maximum tensile strength of range of specification at room temperature". The specification for the 316L bar only lists the minimum tensile strength. Where do I find the "maximum tensile strength of range of specification at room temperature"?
RE: Materials Data for ASME BPVC UG-101 Burst Test Calculation
I just reviewed PG-101, and from my understanding of paragraph a) 2 look at (a). Tests based on yielding of the part can be used to establish internal MAWP, with a ratio of minimum specified yield strength to minimum specified ultimate tensile strength of 0.625 or less.
(b) refers to actual burst testing.
I checked SA-276 which is what the vessel material was purchased to, but only the minimum tensile strength is specified.
Ah, after some additional reading, I believe you need to remove actual samples from the burst tested component (in an unaffected region) and have them tested. The samples should not be torch cut. These values are used in the calculations.
