Blowdown study/sizing help
I just recently been assigned the task of studying a client's pilot plant blowdown system. The objective of the study is to determine whether or not the blowdown tank they currently have is adequate for their system. If not they are going to want a redesign/new size. I am to study the system for normal process upset and for a fire case.
The only information given was:
the autoclave reactor (6000 psig, 1 gallon capacity)
3000 psi rupture disc
blowdown tank (DP-300 psig, DT-400F, capacity-16 gallons)
tank size
blowoff line size
reactor operating conditions:
it can be assumed the reactor is 70% full with liquid
liquid composition is 30% solids (TA/PTA)
balance = acetic acid
450 F
400 psig
I'm not really sure how to proceed with the calculations/analysis with the given information. No inlet or outlet flow rates were specified/given. I have a copy of API RP521 (read specifically thru section 5.4), Crane's 410, and some other papers online.
If someone could steer me toward some equations, book, or methodology that would be useful it would be much appreciated. Fluids is not my area of expertise, so any help would be appreciated.
thanks
tank size
blowoff line size
450 F
400 psig
thanks
