Temperature Analysis
For transient heat transfer analysis one should define the initial BCs first. Initial BCs are difficult to predict within the system. Hence it is advised that one first runs Steady state analysis (Boundary Value Problem) with assigning BC temperature at Measured points . THe STep of Steady State temperature should be followed by Transient Heat Transfer Step. DO you agree with me?
RE: Temperature Analysis
corus
But still I need to run two analyses
Corus : What do you mean boundary conditions that you think will apply
A clearer answer is highly appreciated
Clay1969
For 'boundary conditions I think that may apply' in a thermal analysis I refer to assumptions regarding fluid flow, or whether fixed temperatures apply, or whether radiation is significant or not, or whatever. It all depends.
corus
