Elastomer vs. Foam
Elastomer vs. Foam
Elastomer vs. Foam
Does anyone have information on why one would choose an elastomer over foam for an application, other than price?  I have an application that I have been looking to use either a silicone or urethane foam-in-place gasket, but the thought of an elastomer hadn't really crossed my mind until recently.  If I could find a cost effective elastomer that had the same hardness characteristics of a foam, would it be a feasible alternative?
RE: Elastomer vs. Foam
One very important consideration:
Is the final "material"  created in a factory or by a person on the "construction" site.
"Made in factory" usually implies a lot more quality control than "on site" "mixing/spraying".
The material would be applied in the factory.
We would like to know if somebody use already pressure sensitive adhesive an Acrylic Co Polymer
PANATEX A 5012  low viscosity
PANATEX A 501 D Medium viscosity
Used with a film one side sticked on foam other side to precoated steel sheet.
Any recommendations or experience ?
Comments wellcommed
