BOILER PRESSURE
BOILER PRESSURE
WHAT WILL BE THE PRESSURE GAUGE READING , AT THE BOTTOM OF A 6" PIPE, FILLED WITH WATER, 72 FEET HIGH ?
RE: BOILER PRESSURE
In order to answer your request, I think you have to furnish either the density of the water or its average temperature. You should also state if there is any vapor pressure over the surface of the water level - i.e., is this a closed or open standpipe?
RE: BOILER PRESSURE
RE: BOILER PRESSURE
72 ft fresh water @ 60F => differential pressure of 31 psi.
BigInch
-born in the trenches.
http://virtualpipeline.spaces.msn.com
RE: BOILER PRESSURE
P=H*sg/2.31
P= pressure, psi
H= head or height, ft
sg= liquid specific gravity (at temperature)
P=72*(1)/2.31 = 31.1 psi
RE: BOILER PRESSURE
RE: BOILER PRESSURE
The estimation by dtn6770 is correct as long a the zero reading of the gage corresponds to the actual prevailing atmospheric pressure.
