Fanuc Memory card for RJ2 controller
Hello
I’m looking for a memory card for Fanuc RJ2 controller to do backups and change data between robot and Pc.
Does any body know how can i sell this card?
Thanks !
roland
RE: Fanuc Memory card for RJ2 controller
Fanuc can sell you their DOS-based program called "KFLOPPY".  It is a floppy drive emulator.  Connect your PC to RJ2 via RS232 cable and transfer files.
TygerDawg
Thanks TygerDawg
I work with the "Kfloppy", the problem is the data save takes a long time, i have 82 old robots to program. Normal PCMCIA card works only up to RJ3, yes i can by the special PCMCIA card by fanuc, but that cost me 400$.
greet from Austria
roland
I have an RJ Controller.  How do I start the process to load SpoTTool onto the RJ controller.  I have the KFLoppy software and SpotTool image but no documentation on how the start the transfer process.  It is different from the menus given for a RJ2 controller.
