Is a Nation "Plural" or Singular?
Which is correct?
Canada wins their rugby match against Ireland! or
Canada win their rugby match against Ireland.
(I'm not talking about the validity of the statement - only on the use of the plural or singular verb!!)
RE: Is a Nation "Plural" or Singular?
"Canada wins its rugby match against Ireland!"
or
"The Canadians win their rugby match against Ireland!"
Don
Kansas City
If you extened your sentences, as in:
Canada wins their rugby match(es) against Ireland every time!
then the "plural" form of the verb would make sense.
That being said, it's not actually plural is it? Isn't that an adverb or something like that?
Jeff Mirisola, CSWP
CAD Administrator
SW '07 SP1.0, Dell M90, Intel 2 Duo Core, 2GB RAM, nVidia 2500M
http://designsmarter.typepad.com/jeffs_blog
A nation in conceptual meaning is a plural word because it means a group of states regions or peoples but grammatically speaking is a singular word. The name of the nation can be either singular or plural; for instance United States is plural, Arab Emirates is plural, Spain and Canada are singular. The name of the nation being plural or singular should follow the grammatical rule for the plural or singular, I suppose.
BigInch
-born in the trenches.
http://virtualpipeline.spaces.msn.com
The United States is at war in Iraq.
The United Arab Emirates is an oil-producing nation.
Canada wins their/it's match. Singular, but brings up another issue. Either 'their' or 'it's' is correct. The notion of the 'singular they' is growing in popularity, especially in statements just like this, where the antecedent is a collective, singular, and personal noun.
Good Luck
As a circle of light increases so does the circumference of darkness around it. - Albert Einstein
Uh? What part of Britain is this then? Collective nouns are singular here too. The only word (type) that confuses the unwashed here is "none". People tend to (wrongly) treat it as a plural.
Good Luck
Good Luck
My recollection may be faulty, but I am pretty sure that I have come across a good number of instances of corporate business name usage something like:
"Ford are expected to lose a lot of money this year."
I have been wondering about that usage for quite a while.
Good Luck
Bazaar is a lot of people. That doesn't make sense.
There is referring the subject or object?
So " Bazaar is a lot of people" makes sense to me.
a lot= one lot, plural would be lots.
There are lots of people at the party. or There is a lot of people at the party.
A Bazzar is a sigular item.
So a Bazzar can have a lot of people or lots of people.
thread1010-104593
There are several issues:
One, I would think a Nation is singular.
Two, News headlines do not always adhere to proper grammar.
Third, Is a Nation masculine, faminine or a neutral entity?
I have often read nation or a country referred to as She or her (feminine entity).
corus
You are both sort of in a gray area. It depends on what your subject actually is, and possibly your version of English. In SomptingGuy's case, the more common usage (at least in the US) would be to say that "tickets" is the subject, which is plural, and "a handful of" is an adjective phrase describing the number of said tickets. Replace "a handful of" with a specific number and you will see that "There is six tickets left" is obviously incorrect. However, another possible interpretation is that "handful" is the subject and "of tickets" is the adjective phrase, such as in the sentence "His handful of tickets is bigger than mine".
rbulsara's situation is the same. The phrase "a lot of people" is most commonly understood to be "people" with "a lot of" being the adjective phrase describing quantity. So you would say, "There are a lot of people at the auction." "A lot of" modifies "people".
However, if there happened to be a big box of Christmas ornaments being sold all together, you would say, "There is a lot of Christmas ornaments being sold at the auction." "Lot" is the subject and "of Christmas ornaments" describes the lot that is for sale as a single item.
I can understand "are" preceding "a of something" in the following case:
For example: They are a bunch of morons.
But not: There were a lot of people.
I would say "There were lots of people or there was a lot of people"
Non-US english may be different.
"There is a lot of people" all the time.
Strictly speaking, is not the word "people" the object of the prepostion "of" and not the subject of the sentence? It would be incorrect to say "there ___ a lot of they"; obviously it should be "there ____ a lot of them."
Is the subject "lot" or is it "there"? Or with the verb "to be" is there even a distinction? "There" can take either the singular or plural verb (is/are). What about "lot"? "A lot" connotes singular, so I suppose it would thecnically be correct to say "There is a lot of people" but that doesn't really sound right does it? I'm willing to accept "There are a lot of people" as acceptable grammar and an exception to the rule.
But why don't we just say "Wow, what a crowd!" and avoid the issue altoghter?
"A lot of" is most commonly used in US, informal English as an adjective substitute for "many" or "much". If that is the intended meaning, the correct wording is "There are a lot of people at the auction". To test and see if that is the intended meaning, replace "a lot of" with some actual number and see if the meaning changes: "There are 10,000 people at the auction" means the same thing - it's crowded.
Much less common usage, but also grammatically correct, would be if the intention is to say that there is a group of things, and those things just happen to be people. In that case, "lot" is the subject. If changing "a lot" to "a group", "a team", or "a gathering" really says what you want to say, then you could say "There is a lot of people at the auction." Again, this usage makes no implication of a large number. However, if you are really referring to a group you should probably use "group" instead of "lot". Otherwise, people will be confused with common usage and think you're trying to describe a crowd.
It is a pretty fine distinction. Either sentence can be gramatically correct standing on its own, they just mean different things.
There is a lot of people -> There is a group of people (no implication of large numbers)
There are a lot of people -> There are many people
Check http://owl.english.purdue.edu/owl/printable/537/ for reference if needed.
But I can't agree that people is the subject. In this sentence it's clearly used in the objective case, for which the pronoun "them" could substitute: "There are a lot of them." Them can't be the subject* since subjects must use the nominative case (ie, they), so neither can the word for which them is subsituting (people). That was my reasoning anyway...
*Unless one is speaking redneck "Them's nice cars in your yard."
In the sentence, "There are a lot of them.", the subject is 'lot'.
Good Luck
Germany - the fatherland
France - the motherland
Holland - the Netherlands (ha ha)
After the civil war, it changed to "the United States is..."
This sort of reflected the emphasis on more federal control over the country and less state independence.
hurts my ears just as much as
"the United Kingdom are"
would.
My ears tell me that whenever the noun is plural, the verb should be plural, no matter what.
Cf "more than one person is sick", "less than 2 people are eating".
Even though mathematically speaking "more than one person" refers to something plural (just like, geographically speaking, "the United States" refers to one country), grammar does not look further than the tip of its nose and considers it singular. At least in my universe.
"The USA is a powerful nation"
& In another context
"United States of America are composed by 51 states? I am not sure of the amount, but somebody will correct me.
Cheers
Luis
In French I believe it is unthinkable to say anything else than "les Etats-Unis sont une nation puissante" to use your first example.
I agree though that if you replace United States by US it hurts less to say "is".
Portuguese Grammatik is very similar to the French
In Portuguese we say “Os Estados Unidos são uma nação poderosa”
Italians will say ” Gli S.U.A. sono una nazione potente”
Spanish say "Los E.E.U.U. son una nación de gran alcance"
I suppose we have to understand JAE quote
After Lincoln, US became a truly Union of states. Before Lincoln US were more a confederation.
For that reason we have to understand the quote:
“The United States is a powerful nation”
I also suppose for UK we have to say, “ United Kingdom is an old nation”
In Portuguese we say “O Reino Unido é uma velha nação”
The same way the French say “Le Royaume-Uni est une vieille nation”
Luis
The United States is a member of the UN Security Council.
The United States are empowered to enact local legislation, if not in conflict with federal law.
Good Luck
Sokhansanj I.P.
Professional Patent Protection Services
WWW.SOKHANSANJ.COM
I think that you can't necessarily look at the "is" in "there is" as an indicator of number in what follows. In many people's dialect, "there is" (or more usually "there's") has become a standalone construction (a locative, for those who care) along the lines of the French "il y'a", which is the same for plural and singular.
Hg
Eng-Tips policies: FAQ731-376
There is much effort placed on good grammar and corret spelling on one side of the pond while grammar and spelling is not as important as delivering the message.
As long as gramma still makes good pies and cookies, everybody/every body is happy.
Bob Levy
Kevin Hammond
Mechanical Design Engineer
Derbyshire, UK
Hg
