Applying Macro to Document opened
Hello All,
I have searched for responses thanks to the search tool, without success, so here my question.
I have also searched in Doc on line help.
I am trying to develop a macro, which basically, open 2D files, create unfolded view from 3D and save as with .dxf format.
For the moment, the macro is working for a particular 3D CATPart (name of the CATPart written in macro).
the next step is to make the macro working for active document.
My question is : How can I make the macro working on 3D active document ?
here below the code:
' creation unfold view dans 2D
Dim documents1 As Documents
Set documents1 = CATIA.Documents
Dim drawingDocument1 As Document
Set drawingDocument1 = documents1.NewFrom("C:\Temp\Drawings\ANSI_F.CATDrawing")
Dim drawingSheets1 As DrawingSheets
Set drawingSheets1 = drawingDocument1.Sheets
Dim drawingSheet1 As DrawingSheet
Set drawingSheet1 = drawingSheets1.Item("F1.1")
drawingSheet1.Activate
Dim drawingViews1 As DrawingViews
Set drawingViews1 = drawingSheet1.Views
Dim drawingView1 As DrawingView
Set drawingView1 = drawingViews1.Add("AutomaticNaming")
Dim drawingViewGenerativeLinks1 As DrawingViewGenerativeLinks
Set drawingViewGenerativeLinks1 = drawingView1.GenerativeLinks
Dim drawingViewGenerativeBehavior1 As DrawingViewGenerativeBehavior
Set drawingViewGenerativeBehavior1 = drawingView1.GenerativeBehavior
Dim partDocument1 As Document
'Set partDocument1 = documents1.GetCurrentDocument
Set partDocument1 = documents1.Item("123456.CATPart") -------> part used for creation. How can I create a general application ? (by selecting the active document )
Dim product1 As CATBaseDispatch
Set product1 = partdocument1.GetItem("PartNumber")
Thanks for your help, and sorry in advance if this question has already been asked.
Best Regards,
Yann
Best Regards,
Yann
RE: Applying Macro to Document opened
