Average result
Average result
Average result
I´m solving a 3D flow problem in Flotran with elements Fluid142.
My problem is getting average result of PCOE and PRES on surface A10.
How can I do this?
Thanks a lot,
Robert
RE: Average result
Robert, if you're familiar with APDL this is easily done.  These values are easily retrieved using the ETABLE function.  You can then compose a *do loop to construct an array of these values for different elements and nodes on the surface of interest.  Retrieve values using the *get function.  You can then operate on the arrays using *vscfun or another command to calculated the values you are interested in.
Good luck,
-Brian
RE: Average result
Hi Brian,
it isn´t as easy as I thought. With postprocessing I have some problems. Could we try an example? How is it possible to determine average result of PCOE on area A10?
Thanks a lot,
Robert
Program:
/FILNAME,RO_triangular2,0
/CWD,'E:\ANSYS\RO_triangular mesh2'
/TITLE,Rectangular object-triangular meshing
aa=5
bb=3
cc=5
/prep7
k,1,0,0,0        !node definitions
k,2,0,4*bb,0
k,3,0,0,3*cc
k,4,0,4*bb,3*cc
k,5,6*aa,0,0
k,6,6*aa,4*bb,0
k,7,6*aa,0,3*cc
k,8,6*aa,4*bb,3*cc
k,9,-6*aa,-11*bb,-10*cc
k,10,-6*aa,15*bb,-10*cc
k,11,-6*aa,-11*bb,13*cc
k,12,-6*aa,15*bb,13*cc
k,13,12*aa,-11*bb,-10*cc
k,14,12*aa,15*bb,-10*cc
k,15,12*aa,-11*bb,13*cc
k,16,12*aa,15*bb,13*cc
v,9,10,12,11,13,14,16,15    !volume definitions
v,1,2,4,3,5,6,8,7
VSBV,       1,       2      !substracting volumes
ET,1,FLUID142            !element type
MPTEMP,,,,,,,,          !material properties
MPTEMP,1,0
MPDATA,DENS,1,,1.25
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,VISC,1,,1.79e-005
LESIZE,ALL, , ,15, ,1, , ,1,    !element size selection
MSHKEY,0            !mesh generation
MSHAPE,1,3d
CM,_Y,VOLU
VSEL, , , ,       3
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
da,all,vx,0,1            !boundary conditions on areas
da,all,vy,0,1
da,all,vz,0,1
dadele,2,all
da,1,vz,-26,1
da,3,vz,-26,1
da,4,vz,-26,1
da,5,vz,-26,1
da,6,vz,-26,1
da,2,pres,0,1
FLDATA1,SOLU,FLOW,1
FLDATA1,SOLU,TURB,1
FLDATA1,SOLU,RDSF,1
FLDATA2,ITER,EXEC,50,
FLDATA5,OUTP,RESI,1
FLDATA7,PROT,DENS,AIR-SI
FLDATA8,NOMI,DENS,-1
FLDATA7,PROT,VISC,AIR-SI
FLDATA8,NOMI,VISC,-1
FLDATA24,TURB,MODL,1
FLDATA24,TURB,CMU,0.09,
FLDATA24,TURB,C1,1.44,
FLDATA24,TURB,C2,1.92,
FLDATA24,TURB,SCTK,1,
FLDATA24,TURB,SCTD,1.3,
FLDATA24,TURB,ININ,0.01,
FLDATA24,TURB,INSF,0.01,
FLDATA24,TURB,RATI,1000000,     !higher turbulence value
FLDATA24,TURB,SCTT,0.85,
FLDATA24,TURB,SCTM,1,
FLDATA34,MIR,MOME,0.2,      !matrix has a negative diagonal problem solution
FLDATA34,MIR,TEMP,0.2,
FLDATA34,MIR,TURB,0.2,
FINISH
/SOL
SOLVE
FLDATA24,TURB,RATI,1000,    !default turbulence value
/COM,,Steady State Analysis,0
FLDATA2,ITER,EXEC,100,      !100 iterations
FLDATA2,ITER,OVER,0,
FLDATA2,ITER,APPE,0,
FLDATA3,TERM,VX,0.01,
FLDATA3,TERM,VY,0.01,
FLDATA3,TERM,VZ,0.01,
FLDATA3,TERM,PRES,1e-008,
FLDATA3,TERM,TEMP,1e-008,
FLDATA3,TERM,ENKE,0.01,
FLDATA3,TERM,ENDS,0.01,
FLDATA5,OUTP,SUMF,10,
FLDATA5,OUTP,PTOT,1
FLDATA5,OUTP,TTOT,0
FLDATA5,OUTP,HFLU,0
FLDATA5,OUTP,HFLM,0
FLDATA5,OUTP,STRM,1
FLDATA5,OUTP,PCOE,1         !pressure coefficient output
FLDATA5,OUTP,MACH,0
FLDATA5,OUTP,YPLU,0
FLDATA5,OUTP,TAUW,0
FLDATA5,OUTP,RDFL,0
SOLVE
FINISH
/POST1
SET,LAST
wpstyle,15,5,0,60,0.001,0,1,,5
wpro,,,-90.000000
wpof,,,-15.000000
WPSTYLE,,,,,,,,0
/EFACET,1
PLNSOL, PCOE,, 0
/GRAPHICS,POWER
/TYPE,1,8
/CPLANE,1
/SHADE,1,1
/HBC,1,0
/REPLOT
