chiller selection
chiller selection
hi
I need a chiller
with 60ton refrigeration capacity
chilled output temperature -20(C)
what type of chiller is the best?
thanks for reply
I need a chiller
thanks for reply
RE: chiller selection
Go for the hot and cold well tank as Quark suggested for stable temperature under varying process load
is there absorption chiller with negative temperature working condition?
We have (or had) both screw and recip chillers working in that temeperature range. Right now we are using screw type chillers. If your load is variablein a wide range, you might want to try screw with VSD. This will give you some significative savings in temrs of energy.
