Silver recovery system in a mirror line
Our system of silver recovery consists of 2 filters:
the first one is 0.5 microns and the second one is 0.2 microns. The Ag particles in the waste water decrease from about 15 ppm to 0.6 ppm in the water sewage.
The regulations requirement is less than 0.1 ppm.
We are thinking about Decanting vessels( with floculant) or resin colums, since the amount of silver may be to low for mechanical separation.
Some one has experience and can give me a tip about a recommended method to decrease this Ag content.
Any advise will be highly appreciate.
Best regards,
Osna
RE: Silver recovery system in a mirror line
Have you considered a reverse osmosis filter?
TTFN
Thank you IRstuff for the reply.
Can you please give some more details about your suggestion?
The water flowrate is 55 liters/ minute.
Here are some references to solutions used by the photographic industry to remove and or recover silver from process streams. Each of the process has it's own efficiency.
Have you asked your trade organization about this problem as you will note in these references there are references to organizations like the Silver Council.
http://www.silvercouncil.org/html/index.htm
http://www.p2pays.org/ref/02/01994.pdf
http://www.kodak.com/global/en/service/faqs/faq5024.shtml
http://www.creweb.com/equip.html
We had a process that required us to remove Silver to very low levels and we used precipitation or Chemical recovery cartridges depending on the starting levels. We got
low levels, but not as low as you trying to achieve.
Thank you unclesyd fo the valuable site
Osna
