INTELLIGENT WORK FORUMS FOR ENGINEERING PROFESSIONALS
Member Login
Are you a Engineering professional? Join Eng-Tips now!
Talk With Other Members
Be Notified Of Responses To Your Posts
Keyword Search
One-Click Access To Your Favorite Forums
Automated Signatures On Your Posts
Best Of All, It's Free!
Partner With Us!
(Download This Button Today!)
Member Feedback
"...I train people in ACCESS. I make sure they know about
these forums, give them some training on how to use the site,
and have a shortcut to it on their PC's..."
I am trying to keep it as simple as possible. I have scoured loads of sites etc, an have even found the circuit I want, or should I say it is described as the one I want.
I have found a simple circuit which I replaced R with a potentiometer to make the output variable, but the aim is to make this a one time circuit. I want to push a current through the circuit it fire for a variable amount of time (via the potentiometer), then stop even though the trigger has not.
I have been told that this is done with the use of and extra capacitor, resistor, LED and Transistor (used as a not gate) to get this to work. So far all of the layouts I have been given have not worked.
I seen the post at thread240-151528 (sorry could not find how to add it as a link). Seemed to be asking a similar question and woundered if that was the way to go? Any ideas would be great.
Thanks Scott
Eng-Tips Forums is Member Supported. Click Here to donate.
I have tried that I think that I mite be mis-understanding or expalining it wrong. I have a trigger which will send power but does not stop. From that trigger I want a short pulse. All of the one shot monostable circuits I can find seem to need a trigger which supplies a voltage/current for less time than the actual output.
OP: "...a trigger which will send power but does not stop. From that trigger I want a short pulse."
Sounds like a 'Power On Reset' circuit. Apply power to the circuit, and get a nice clean reset pulse. There are a million solutions including application-specific 3-terminal devices. Most POR emit a low-going reset pulse (ground seeking) - but inverters are easy.
I have a motor which gets switched, but want to put a one shot pulse on the on the motor. The idea is the switch is thrown then the motor will power for a short while then stop, even though the switch has not been turned to the off position. I would like to make the time the pulse runs variable also. It runs off 12 volts and the time variation should be between 0.5 of a second to 10 seconds.
I have read through all of the material given and it seems similar to what I have tried. Most of them continued to pulse the motor as the input was still high.
Simply differentiate the switch closure: Let be R1=1 Mohm, R2=1kohm, C1=.1 microF. Sw1 = Normally open switch. (each line is one node, each part has two pins, 1. and 2. )
When the SW is open the C1 charges up to V+ through R1 in about .1 sec. When Sw is closed, C1 discharges through R2, generating a single positive pulse of about .0001 sec. Use this to trigger the 555
Are you reading the same datasheets I'm reading? There's a reason why these are called "EDGE-TRIGGERED" one-shots. The 74121 can be programmed for a pulsewidth up to 28 seconds
DESCRIPTION: Electrical/Electronic engineering other topics technical support forum and mutual help system for engineering professionals. Selling and recruiting forbidden.
