triangulation
triangulation
triangulation
Is it possible to save solid object as a set of small triangles. I'm using AUTOCAD 2000
Thank you
RE: triangulation
Try the "3dsout" command to create a ".3ds" file, then "3dsin" that file, it should be 3dfaces.  Not sure if it will be triangular faces.
