short circuit current
Does the short circuit current change at all if 3 single phase transformers are used connected in delta - wye vs. one standard 3P delta wye transformer?... assume 2.5% impedance typical...
TULUM
TULUM
RE: short circuit current
I understand that three legged three phase transformers are intolerent of unbalanced loads. If the loads are not balanced, there is no return path for the unbalanced flux and it has to return through either the air or through the core supports and the housing.
Any comments on this?
respectfully
Respectfully
