Estimation of Center of gravity of a CRANKSHAFT
Hi All,
I have a small project namley to calculate the centroid of a crankshaft so that i can estimate the real mass of counter weight in the shaft.Do any body have an idea about how to handle this problem.
Definitly i know i will get some clues from these great forum.
i would be very greatful to  recieve some tips from you because i want to estimate first and then i run the same data in a program and then compara my result.
Cu
martino6000
RE: Estimation of Center of gravity of a CRANKSHAFT
It isn't cg that is important, but mass at a radius, which controls rotating and reciprocating balance, and then the location of masses along the crankshaft which controls moment balance.
More detailed information is found in engineering-oriented engine books, and many dynamics of machinery books. A university library is a good place if you have one nearby.
Dynamic balancing is the only real way to guarantee success
Dynamic balancing won't help. EngJW is correct, this is second year mechanics.
Cheers
Greg Locock
On a single cylinder engine yes but with multiples you would need to be able to assign mass to the individual pins and webs, difficult on a straight six?
