Small Gears
Small Gears
I'm currently using solid edge for a uni project and very much teaching myself as I go along, but I've hit a problem. I want to put a small gear into my part (about 20mm diameter) but when I try and create it all I get is a cylinder with no teeth. I can manage to create larger diameter gears fine so I know it's to do with the small gear diameter but I'm not sure as to how this can be done.
If anyone could tell me it would be very much appreciated.
Another query I have is whether or not it's possible to draw a rack and pinion set up in solid edge (v18). I have had to draw the rack myself as I couldn't find a feature to do so, but if it's possible to do it any other way it would be very usefull as I have another rack to draw yet.
Thanks.
Thanks.
RE: Small Gears
how did you try to create the small gear, using Engineering
Reference
or just by sketching it, and doing a protrusion?
For a rack you may create it like this
Rack
HTH
dy
RE: Small Gears
I was using Engineering reference for creating the gear. I suppose I could just sketch it can do a protrusion, but I was hoping to make it using engineering reference and wasn't sure why it doesn't work.
Thanks.
RE: Small Gears
I've checked it with V18 and it did work:
Gear
the outside diameter is 21.xxx mm (all features suppressed)
After pressing Create you have to save 2 times and then reopen
either one (it will create always 2 gears)
BTW: when doing it 'roll your own' just model one tooth and
then use circular pattern to get it proper
dy
RE: Small Gears
the comment:
After pressing Create ...
is related to the Engineering Reference not to the sample
dy
RE: Small Gears
Unfortunately that file you put up wouldn't open for me as it was just telling me it was corrupt.
RE: Small Gears
I've reloaded it so the above link is still valid
Outside diameter is 21,6 #of teeth 25
Suppressed means: when you open the file you will see
in the edgebar that all features show a read cross and
nothing is displayed. Just select them all --> RMB
unsuppress. I've done this to keep the file small.
dy
RE: Small Gears
Now I just need to make a rack to fit the gear and I'm all set, but hopefully that shouldn't be too difficult.
