Aligning cross section sheets in Geopak
I am trying to center cross sections on a 20 scale sheet using
geopak to create the sheets. For some reason geopak keeps placing the sections near the bottom of the sheet, while I would like to keep them in the center. Any suggestions?
RE: Aligning cross section sheets in Geopak
Under your sheet run you will need to set your bottom dimension. If you are using V8 look under Margins and Spacing. However if you are using Microstation J or Geopak 2001 Under Cross Section Sheets go to Vert Clear Zone.
Hope this helps.
Namdac
