What are theese hydraulic devices
I wonder if somebody on this forum can tell spot what theese adjustable hydraulic devices are ? (See pic): http://www.flickr.com/photos/14275989@N00/305132319/
The devices are inserted into a hydraulic block and looks like they are adjustable. Some numbers are written next to the devices on the hydraulic block with a permanent marker. Perhaps pressure ? Flow ? Looks like some calibration tags or something. The hydraulic block is fed by a double set of hydraulic gear pumps. It has a servo valve for flow control and theese are mounted under the block.
Could it be relief valves ?
Flow or pressure valves ?
Any hints would be appreciated !
Morten Hansen
RE: What are theese hydraulic devices
"Could it be relief valves ?"
YES!!!
"Flow or pressure valves ?"
YES!!!
Since these type valves usually have an adjustment as shown in your picture. Also, other valves, such as Pilot Operated Check valves may have what appears to be an adjustment but is actually a manual release control.
Many of these Screw-In Cartridge valves have information stamped on one of the flats on the hex sections. If you can see the manifold check out the Flats.
I checked six manufacturers catalogs on Screw-In Cartridge valves and did not see any with the configuration shown in your picture. Needless to say I may not know about all the companies, especially non US, who make Slip-In Cartridge valves.
Bud Trinkel CFPE
HYDRA-PNEU CONSULTING, INC.
http://www.fluidpower1.us
OilControl pressure relief valves VS-80.
Best regards,
Luka
Hello Lukec! Thanks for spotting what the devices are !
regards
Morten
Are there any other way you could scan and put the catalog page on flicker.com or something ?
Alternatively: Do you have a link to the manufacturers site or the name of the manufacturer ?
regards
Morten
