Motors for borehole submersible pumps
Why in dry motor submersible pumps, the motor has a limitation that it can't be used above 20m.whereas the wet motor submersible pump can be used till 350m ?
RE: Motors for borehole submersible pumps
Actually below 20 metere submergence.
Probably because of the water pressure at 20 metres - how do you ensure no ingress of water into a dry motor --- whereas for a "wet" motor unit - it's already wet :)
Phitsanulok
Thailand
