Visual Basic 6.0 Write to a text file
Dear All,
I would like to know to write data from a group of .csv files to a newly created .csv file. Any ideas?
This is my code so far
Dim streets As Integer
Dim blpus As Integer
Dim addresses As Integer
Dim paonaddress As Integer
Dim saonaddress As Integer
Dim newfile As Integer
Dim addressdata() As String
Dim a As Integer
MyHeaderrecord.NameofFile = sourcefilename
Unit = FreeFile()
Open sourcefilename For Input As #Unit
streets = FreeFile()
Open "c:\temp_streets.csv" For Output As #streets
blpus = FreeFile()
Open "c:\temp_blpus.csv" For Output As #blpus
paonaddress = FreeFile()
Open "c:\temp_paon.csv" For Output As #paonaddress
saonaddress = FreeFile()
Open "c:\temp_saon.csv" For Output As #saonaddress
Do
Line Input #Unit, RecordData
Select Case Mid(RecordData, 1, 2)
Case "10"
header = RecordData
Case "11"
Print #streets, RecordData
' Case "21"
' Print #blpus, RecordData
' Case 24
' addressdata = Split(RecordData, ",")
' If addressdata(6) = """""" Then
' Print #paonaddress, RecordData
' Else
' Print #saonaddress, RecordData
' End If
Case 99
trailer = RecordData
Case Default
End Select
Loop Until EOF(Unit)
Close #streets
Close #blpus
Close #paonaddress
Close #saonaddress
newfile = FreeFile()
Open ("c:\pete_new_file.csv") For Output As #newfile
**** I am stuck here ****
End Sub
Dim a As Integer
Unit = FreeFile()
blpus = FreeFile()
Do
Case "10"
header = RecordData
Case "11"
' Case "21"
' Case 24
' Else
' End If
Case 99
Case Default
End Select
Close #streets
Close #blpus
Close #paonaddress
Close #saonaddress
End Sub
RE: Visual Basic 6.0 Write to a text file
http://www.tek-tips.com/threadminder.cfm?pid=222
TTFN
