"cold welding" of aluminiumto die when blanking
Hi all
I have a continuous problem of the aluminium sheet (0.4mm), that I am blanking, welding to the inside of the die. I have tried more and less clearance as well as reducing the die land to about 1mm, all to no avail. Is there any special tool steel that the aluminium wont stick to or a tough enough coating that will help? Both die and punch are well polished and because of further processing of the aluminium I cannot use any form of lubricant.
Timfitz
Timfitz
RE: "cold welding" of aluminiumto die when blanking
http://www.welding-advisers.com/
Thanks for the ideas.
Paper sheets might work I will try today and let you know, talc will give us problems in production of the blanks (printing etc.). We are blanking up to 12 000 components per run and need to clean after every 200 to 300 units.
Timfitz
thread281-170966
Cory
You also state that no lubricant can be used, does that include a product that will evaporate? I have seen triethylene used where the part must be grease free.
Paper does not apper to make much of a difference and the operators find it very awkward to feed etc.
The polishing is a very valid point, the die and punch will both be polished in the oposite direction to the movement.
The evapotating lubricant might be an option. Production on this product has stopped at the moment so I will test when there is some time available on the press.
TimFitz
