Consideration of check valve
i m designing a relief valve for tube side of Heat exchanger, tube side of HE feeds the reactor, and reactor has PSV. There is a check valve in line between HE and reactoe. Can i consider that relief valve on reactor can provide protection to tube side of HE?
RE: Consideration of check valve
I wouldn't.
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
What relieving scenario are you trying to protect the heat exchanger tubes from?
