need help urgently
need help urgently
hi..
i have a lot of problems:
1. i dont know should i install something like c++ or fortran to run patran and when i should install it before or after
2. if i dont need that programs i make analysis and the program make analysis but i search for the result no way to find them
thank you all
thank you all
RE: need help urgently
second, see in the properties of the patran link "working directory" where it's working.
but i don't quit understand you but if you mean where i save the files i save it on my documents and i tried to put it inside the patran in the C: directory but still not working.
please if you can be more patient and make it more clearly because i am newly with this program.
thank you
thank you
Good Luck
Thomas
thank you all
thanks
You have pirated this software, which is illegal! That is what johnhors is referring to. I suspect that most of us will be very reluctant to help at this point.
sorry
your files are most likely located in your windows\temp directory, or other temp directory.
and to run the analysis you need nastran, not patran. Having patran with no nastran is useless (unless all you want to do is make mesh).
If you have a "real" software you also have support or at least a licence key. So what you have is (best case) a worthless CD or (worst case) illegal software. For both cases I doubt that you will get much help in this forum.
/Thomas
> I guess in Italy this is common practice.
fkmeyers,
do you have any facts to support this sentence? Because at first sight I find it vaguely offensive.
'Ability is 10% inspiration and 90% perspiration.'
Although it's going to offend a few people here and there, I believe that pirated software for EDUCATIONAL purposes is ok. It's impossible to get the high-end software with all the features for learning. I learned all of my CAD from such software, but in my workplace I use ONLY legit software, and the skills I aquired using "pirated" software.
Those who sell pirated copies whould be sent to prison for a long time.
http://www.serci.org/2002/Rodriguez.pdf
The report was done 5 years ago and things may have improved since then.
Yes I think Russia could now be in the 90's !
On a more serious side judging by his recent absence I guess the OP has got the message, though he did spawn a useful debate on a very serious issue.
fmeyers,
the linked document is coherent with what I found from other sources. Still, a rank perfectly in line with the average piracy rate over EU (46%) in my opinion does not justify for your 'common piracy use' conclusion in Italy. On top of this, I fear this ratings include every kind of software, from entertainment to high-end engineering softwares used in industry/manufacturing.
I think in this latter field Italy is not worse than many other countries.
Here is another more recent report (2005)...
http://
See Table 3. In this one Italy has a 50% piracy rate, Germany is 29%, France is 45%, UK is 27%.
If we are talking about games/movies/general use apps, then Russia and the eastern block are the most illegal, and those countries DO use the $1000's apps illegally - for DCC, CAD, CAE, as well as all the general apps.
