Lorenz equation and plots in MathCad 5
as part of a educational project I am required to plot the Lorenz equations in the x-y,z-x, plots.
has anyone an idea how to do this in MathCad 5 as its new to me.
thanks
thanks
RE: Lorenz equation and plots in MathCad 5
Keystrokes are
Im(results[i)@Re(results[i)
Assuming Im and Re are defined (I think they are).
If you post more detail I'll help.
Cheers
Greg Locock
1) have you done all the tutorials? If not then you will struggle.
2) set up an indexing series, i, for the number of points you want to calculate. In all the rest <something> is a value that you need to decide.
Type i:0;<number of points desired>
3) x[0:<starting value for x>
y[0:<starting value for y>
z[0:<starting value for z>
4) Then solve x,y,z for all the rest of the values
5) Then plot them using
z[i@x[i
and
y[i@x[i
Cheers
Greg Locock
