Finding meteorites.....
I am trying to locate a piece of a meteorite, with maybe the weight of 1 ton, that might be buried to a depth of 10 feet in a plowed field. The meteorite's structial class is finest octahedrite, consisting of mostly iron, and approximately 10 % nickel.
Would it be possible to find something of this size using a strong magnet, say suspended by a string set up to use trianglation from a distance of maybe 100 feet? Just how far would this work, if it works at all?
Thanks, Guys,
jim Peterson
Thanks, Guys,
jim Peterson
RE: Finding meteorites.....
I recommend a gaussmeter probe, one that is sensitive enough to pick up the small, localized variations in the earth's magnetic field. A number of gaussmeter manufacturers make what is called a gamma probe, which might work well for this.
>> 3-axis Magnetometer should detect the mass concentration. Airborne magnetometers are able to detect masscons.
>> Earth resistivity measurements used for oil field exploration ought to be able to detect the anomaly as well.
TTFN
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
TTFN
