cutting parts in assembly
Is it possible to visualy cut parts on half in assembly, to make interior of the assembly visible when rendering 3D images?
thanks.
thanks.
RE: cutting parts in assembly
It basically takes a slice, and returns the result in one of several ways, including a volume showing the cutaway of the solid body or assembly.
Catia Design|Catia Design News|Catia V5 blog
Analyze - Sectioning
With the DMU product, the section appears in the tree as an application, and you can export your results.
I've seen 3d images 1/4th cut part in assembly to see the interior in pro engineer.
So there is no way to do this in catia?
