Volume of dumptruck
Volume of dumptruck
How many yards of fill can a typical dumptruck hold? Can't you use about 3 yds/truck for purposes of estimating?
Stoddardvilla
Stoddardvilla
RE: Volume of dumptruck
Also, I was just curious about what kind of ESAL value a typical concrete truck would have.
Any help would be greatly appreciated.
Stoddardvilla
"...students of traffic are beginning to realize the false economy of mechanically controlled traffic, and hand work by trained officers will again prevail." - Wm. Phelps Eno, ca. 1928
"I'm searching for the questions, so my answers will make sense." - Stephen Brust
Anyway, I just need a rough estimate of ESALs. I don't need exact values for the trucks because it's all just a rough guess while trying to be very conservative.
I'm just looking for typical values of dumptrucks used to haul cut/fill material on regular construction projects. I'm looking for a ballpark number of ESALs erroring on the conservative side.
Is 3 ESALs reasonable for a dumptruck that will haul 5 CY? Is it too conservative?
Stoddardvilla
How many truckloads do you expect on it?
The standard truck trailer has the capacity to carry much more than 10 cy's but is limited by the DOT 40,000 lbs payload limit.
If you are only doing off road construction, your carrying capacity will be higher than an over the road hauling truck. Suggest you talk to a contractor experienced in that work.
htt
BigInch
-born in the trenches.
http://virtualpipeline.spaces.msn.com
Considering the truck HS20-44 truck that PEinc mentions (3 axles spaced 14' apart at 8k, 32k, 32k) what is a general value for the ESAL?
I'm assuming general conditions of SN=3, pt=2.5. Can anybody help me out with what a general ballpark value for the ESAL will be for this truck? Anything?
My reference doesn't have an ESAL equation and the one that I've seen looks tremendously complicated. Any help on this one would be much appreciated.
Stoddardvilla
What are some typical ESAL values you've come up with for an HS20-44 truck for flexible pavement. I'm just looking for someone with experience here. Please help!
Stoddardvilla
